Old 01-12-2010   #1
Re: Fancy Fuel System Questions
What's the goal of the car?
The 1G stock Fuel Return system (with the exception of the AFPR) is capable of supporting probably anything you plan on throwing at it. I would not touch that if I were you.
The feed system is basically 3/8 line, and is also capable of A LOT. The weak point in the feed system is the banjo fitting on top of the fuel filter, and the next weak point is the filter itself. At your levels right now, what I'd do (which is the actual setup on my car right now) is run the stock lines from the pump all the way to the filter. But put on a high flow filter, and then a nice new -6 feedline. That is what I've been running successfully.
And I also run intank 255hp's in parallel.
