Old 01-29-2010   #20
Re: 4g63t modded estimated awhp?
You can't ever have a very good SAFC tune, since all it does it trick the ECU by modifying the MAS signal. It can't change the ignition timing directly(it does indirectly, often not in the way you want), it can't scale the injectors correctly, it can't adjust the revlimiter, it can't get rid of fuel cut, etc. You can usually get a decent enough with 550s and an SAFC on pump gas or 750-850cc on E85 though. You might want to get some cams. A low compression stock 1G motor with a 1G head and a small 16G isn't going to make amazing power or anything.
