Old 02-08-2010   #2
Re: Adjusting a DSM clutch
I believe the adjustment is the same as a 2g. if you look at the clutch pedal you should be able to rotate the rod and put it to your liking. For it grabbing off the ground you would rotate it to the left (if your looking towards the pedal) if your looking towards the rear of the car it would be towards the right.
