Old 02-12-2010   #1
Re: Stock Parts + more
The GM MAFT is that the Translator box? or is that the GM MAF?
Old 02-12-2010   #2
1QUICK4
Crash Course Racing
1QUICK4's Avatar
Drives: in circles
Originally Posted by Andrew7dg View Post
Making room for another motorcycle
Did you find a good deal on a V-Max?
Old 02-17-2010   #3
Andrew7dg
Built it from scratch!
Andrew7dg's Avatar
Drives: Currently Mitsu-less
Dude, sorry I haven't been keeping up to date with these...
I have the box and the GM MAF (I have two MAF)
*Just to note, I lengthened the wires on the MAFT so that it wouldn't sit inside the engine bay. I have heard that the box isn't weather proof and that keeping it inside is the way to go with these. You will need to reconnect the wire once the wires are run to where they should be*
Originally Posted by turboimports View Post
Does 2.4 block come with front case, etc.?
Its a dirty block but a good block
I cut the timing belt to get the head off.
It is just a stock block out of a hyundai. You would have to get pistons if you want to make it a low compression block.
I have to make room for a V-max!!!
that is the next bike for me!
