Old 03-12-2010   #29
Re: Official You think you have the fastest PC Thread!
Nice rigs for sure. Check out this web site for the latest and greatest in the computer world: http://www.guru3d.com/
Here is the run down on my rig I build a little over a year ago:
- EVGA 780i FTW edition mobo with a 80mm north bridge fan
- Intel E8400 E0 stepping lapped running at 4.275ghz 1.376 volts
- XIGMATEK HDT-S1283 Processor cooler lapped and custom hold down bolts and back brace
-Geil pc6400 800mhz DDR2 stock speeds and volts
-2 BFG 9800GTX+'s graphics cards in SLI Vmodded to 1.385volts running 864/2052/2448 using the tri SLI bridge
-custom Cooler Master case and 8 120mm fans
-Antec 850 modular power supply
-80gb wd main hd
-320gb wd storage drive
-Windows XP
-DVD burner drive
-not so good key board and mouse
-Samsung 24" 1920x1200 5ms monitor
My system as passed many hours of Prime 95 and 15 passes of ITB test. My temps are good for all air cooling. CPU idles at 31c and even ITB did not break 60c, prime 95 hovers around 48c. My graphics cards idle at 39c/42c and full load at 52c/55c my bottom card runs a little hotter then the top card.
I have run some benches, but I play COD4 and GRID along with surfing the internet. But here is the run down of the best I have managed:
Mark03: 83,771 - BFG 9800GTX+ 862/2002/2400 SLi - E8400 @ 4.725Ghz 1.56v Ram@ 800mhz 4-4-4-14-2t - Air
http://service.futuremark.com/result...&resultType=10
Mark 06: 21,572 - BFG 9800GTX+ 862/2002/2400 SLi - E8400 @ 4.725Ghz 1.56v Ram@ 800mhz 4-4-4-14-2t - Air
http://service.futuremark.com/result...&resultType=14
1M Pie/CPUZ record: 9.609 seconds - Intel E8400 @ 4950MHz@1.728v on air | 2x 1GB Geil PC6400 @ 800mhz 4-4-4-14-2t 2v
[img=http://img8.imageshack.us/img8/6624/bednchrun.th.png]
I have not re-run mark 03 or 06 with the Vmodded graphics cards, so these runners were at stock volts of 1.202volts. I can now bench the cards up to 882/2100/2500.
Here a few pics
