Old 03-16-2010   #11
Re: Whats new with Teh Gheyrod...
Per request here is my entire mod list:
Power: Buschur turboback exhaust (straight 3” w/testpipe), Buschur ported/coated exhaust manifold, Buschur coated stainless steel o2 housing, self-ported turbine housing, Buschur intake pipe, Perrin air filter, Perrin FMIC, Nisei IC piping kit, Walbro 255HP fuel pump, DB Performance MBC, FIC 850cc fuel injectors, FP4R MIVEC camshafts, 65mm Mil.Spec throttle body, MAP Rev.3 coated intake manifold w/Magnus heat-barrier gasket and STM EGR block-off plate, Kracka vents (MAP Crankcase Vents) w/ eBay catch-can setup, and all emission systems removed.
Suspension: Swift Sport lowering springs, Whiteline 24mm adjustable rear anti-sway bar, MR BBS wheels w/ Sumitomo HTR Z III 245/40-17 tires, “RobiSpec” alignment by Jeff the Alignment Guy, RS trunk bar, eBay rear strut tower brace, and Binary seat lowering brackets.
Drivetrain: Competition Stage 3 Kevlar clutch disc, Exedy HD pressure plate w/ Mitsu TOB, Competition 10.8 lb. lightweight flywheel, Rosey billet clutch fork stopper, Energy rear differential bushings, Beatrush aluminum driveshaft bushings, Blox billet/poly front motor mount, Fidanza short-shifter w/ aluminum base bushings, Skunk2 counterweight shift knob, Speed-Source brass underhood shifter bushings, and Redline transmission fluid cocktail.
Brakes: RacingBrake ET500 pads w/Girodisc shims, Technafit SS lines, and ATE Super Blue fluid.
Electronics: SpoolinUp COP kit with Denso IKH24 spark plugs, JDM 3-bar MAP sensor, Innovative LC-1 wideband, GM AIT sensor, Nisei mini-battery tray with AMS mini-battery, Defi boost/EGT/oil pressure gauges, Apexi turbo-timer, Tephra v5.10 ECU mods w/tune by Shane at DB Performance, Kenwood CD stereo deck w/ iPod adapter, and hard-wired Passport 8500 X50 radar detector.
Appearance: Mynes hood dampers, carbon fiber COP mounting plate, carbon fiber radiator cooling plate, carbon fiber vortex generator, carbon fiber bumper exhaust heatshield, Primo Performance CAS heatshield, Primo powedercoated brackets, Perrin 2” antenna, partial wire tuck, and 35% tint by Street Scenes Tint.
