Old 03-26-2010   #11
wants to be sideways...
123abc's Avatar
Drives: Loud cars
Re: 4g63tcrazy's new setup for 2010
Not sure how you were able to mount them. You can see the mounting points are completely different. The rear mount was also a lot taller or shorter. Cant remember which..
No, the insert. I was able to change the insert from the fwd metal mounts to the awd metal mounts. I had to use a saw to get the old rubber insert out, but the poly inserts should go in by hand.
Originally Posted by Matt D.
Originally Posted by 93GSX5SD
