Old 05-28-2010   #1
cman3000
Colin
cman3000's Avatar
100m Running Champion!
Part out Thread (Stuff in Minneapolis)
I will be back in Minneapolis this Sunday, and here is a list of the parts I plan on bringing with me. If you are interested in something not listed in here that is in my other thread, let me know and I will bring it back with me.
Front axles - 50
Three Speed Shatter Shield 100
BRAKES:
Front Baer Brakes with Slotted Rotors - $550
New rear calipers with Slotted Rotors 75
Front Stainless Steel Braided Brake Lines 30
FUEL SYSTEM:
Supra TT Fuel Pump 80
3" GM MAF
Braided fuel lines(3) - 65
INTAKE SYSTEM:
Bullseye T04B 50 Trim turbo (oil & water cooled, -10an oil drain) - $500
COOLING SYSTEM:
Alumium Mishimoto Radiator W/Slim Fans (One Puller & One Pusher) - $250
6an turbo coolant feed and return line - 70
SUSPENSION:
Suspension Techniques rear sway bar with Urethane Bushings - 40
GAUGES:
Autometer Phantom:
30psi Boost/Vacuum Gauge 25
Oil Pressure Gauge 25
Volt Gauge 25
Water Temp Gauge 25
EGT Gauge w/sensor 50
125 for all of them
ELECTRONICS:
New Alternator 50
New Coil Packs 25
New Spark Plug Wires and Plugs(BPR7ES) 25
EPROM ECU with Keydiver Chip 180
cman3000 is offline   Reply With Quote
