Re: Starter won't crank, just clicks when I turn the key
I was just reading that the power cables get corroded and can cause symptoms like mine. How should I test the positive and negative lines? Volt meter between the positive cable and the positive terminal on the starter? What about the negative line? I don't have tons of experience using a volt meter to test voltage so please bare with me. Thanks for the help!
