Old 07-30-2010   #11
Re: 91 Galant VR4
This was done with the 4 1600's as the primarys, and no secondary injectors were used. The EMS is not the issue, I tried another EMS and still no #8 injector, so they either need to wired up in a batch fire or I found 2 EMS's that will not run 8 injectors. The boost on WG pressure was 25psi, the 635 run was at 37psi. I am reving to 9500rpm, with how the power is still going up I could rev higher but I am at 90 some % duty cycle on the 1600's and I loose about 6psi of fuel pressure by redline. The intake air temps would only go up about 9deg over the run, but after a few back to back runs the temps would start at 120deg, so we added ice to get that down below 100 before the start of the run. I will see how it does on the street/track IAT wise. Coolant temps were nice and rock solid. The ramp rate was set to 100 and the AM2 correction was around 3-4% most of the night.
