Old 07-30-2010   #11
DB Performance
Drives: Cars
Re: 91 Galant VR4
He isn't that far off. Shootout numbers are closer to SAE Dynojet numbers. STD dynojet numbers are usually 2-4% higher than SAE Dynojet numbers. So add 3% to 740 = 762. then raise the boost 2 psi. 762 + 30whp = 792, then add a degree of timing 792 + 802. Then let everything cool down a lot. 802 + 20 = 822. On high HP cars it's common to see swings of 20-40whp from one run to the next just from heat, a little more or less boost, a little more or less timing, etc. That 832awhp car has put down more on E98 though, but he has been having oil pump problems.
DB Performance is offline   Reply With Quote
