Old 07-31-2010   #7
trunks11
trunks11's Avatar
Drives: like an old lady 458/1000
Re: Didn't bleed lifters - 90 cold compression new engine
Okay after some research I looked a my fuel pump rewire and it was done incorrectly. So I fixed it and the plugs are definately seeing fuel. I've got spark, fuel and compression and still no starting.
I've read coolant temp sensor so I guess that's next. What's wierd is before I could turn on the fuel pump with link and now it doesn't turn on when I check the box. I can here it running when I crank though. I had miswired the relays with 30 the out put and 87 the hot wire input. I wonder if something could have gotten fried from that? My alternator relay is still hotter than hell with just the ignition turned on?
trunks11 is offline   Reply With Quote
