Old 11-09-2010   #6
Re: 6 bolt rebuild swap for 95tsi
Originally Posted by 123abc View Post
He told me he ran the numbers on the tops of the pistons and found one place online that sells them. He said they were stroker pistons out of Canada if I remember right (we're rebuilding the engine as a pair in class).
Does the teacher consider posting on forums part of research? hahah.
Pull the pistons, if you have a stock one to match it up with the stock will be about a CM taller. That will tell you right there whether they are stroker pistons.
I am going to assume you have a stroker crank as you would have noticed right away that the pistons done reach the top of the cylinder.
