Old 02-15-2011   #12
Re: need to limp my car to DB, I live in brainerd area.
Are you just trying to drive the car around or what? If you get that ECU socketed, then you can get a chip and run the 750s. If you wanted to try to run the SAFC, then you would probably want to get some 550s, the 450s will hit fuel cut on an unmodded ECU well before the injectors are close to maxed and the 750s won't tune worth a crap with the SAFC. You could scale the 750s to get it part throttle driveable and go very easy on it.
