Old 03-16-2011   #36
Re: All Sorts of Higher-Flowing fuel pumps coming onto the market
Originally Posted by v8klla View Post
We made 640whp I believe on Kyle's 1g with a rewire, E85 and Deatschwerks pump. We were so impressed we've got 75 on the way
Very impressive for a single pump!
Not true, not all engines share the same BSFC.
Correct, but I would be more worried about injector timing over BSFC unless the flow really goes to shit up top.
Please elaborate?
Fuel consumption will change with airflow demands and rpm. Higher airflow=more fuel requirement to maintain the same AFR. Typically peak BSFC is near peak torque rpm and a little under WOT for throttle. There are some good reads on the topic on google, particularly the engineering forums.
We can usually get a little farther with a Walbro 255 HP on a DSM than a Evo(around 420awhp on an Evo versus 440-460awhp on a DSM), but it is mostly lilkely because every DSM guy has their fuel pump rewired with a big wire going directly to the battery, while almost none of the Evo guys do that.
You definately need more injector to make the same power at a higher RPM. The more RPMs, the less available time an injector has to fire before the next revolution.
word. I think it is hard to find a DSM that is not rewired at this point.
