Old 05-03-2011   #4
Perkul8r
Perkul8r's Avatar
Drives: 91 GVR4
Re: Bent valves? or Droped a valve, Pictures inside!
I had the teeth on the timing belt on my 90 laser sheer off on the crank gear. You could crank the motor over by hand but the cam gears would not move. But when I took off my Valve cover it looked just like that.
So its at least some timing belt or tensior failure.
