Old 05-25-2011   #11
Re: Project Lex
Put the plenum on the runners. Nice new gasket
Also I kinked the fuel rail feed line, so I've decided to just replace it and the stock fuel dampener with a direct -6AN push-lock setup. TNT had all the parts ready to rock for me!
12mm x 1.25 male fuel rail fitting
14mm x 1.5 female fitting attaches to stock line
Straight and 90* -6an push-lock hose ends.
Got some 1/2NPT x 5/8" barbed fittings for the Turbo Oil Drain setup. Figured this will keep it a cheap and simple drain setup.
Here's how she looks right now.
Goodhart you asked about turbo clearance, well here ya go. There is none
ID:	11705   Click image for larger version
ID:	11706   Click image for larger version
ID:	11708   Click image for larger version
ID:	11709   Click image for larger version
