Old 06-19-2011   #11
Mark Leasure
Mark Leasure's Avatar
Re: Mark's 1G Winter Projects
Shitty. I almost didn't notice the difference until I looked at the scale on the left, goddamn! Hopefully you can get it back together by Proving Grounds!
I should have no problem attending the MAP event with the car. Thanks to MAP for getting me a QM flywheel with ring gear installed asap and to 95Talonracer for the crankshaft! I ordered all of the necessary parts when I finished the diagnostics. It also damaged the main timing gear and the factory crank dampener too. I took the old crank out yesterday and installed the freshly balanced and polished OEM crank. The old crank doesn’t look bad, it could be used again, but will need some rnr to true up the end surface. I came to find out that the crank press pin that I ordered from Mitsu was incorrect….So I need a crank to flywheel pin before I can get the car running. I still put the motor in today, with no trans. It will be easier to correctly torque the flywheel with the motor in the car. I just hope all goes well this week!
