Old 07-05-2011   #1
Onefast99gsx
1999 Mitsubishi GSX For Sale
Hello everyone. I have decided to sell the GSX and move on to a family vehicle. There is 107,000 miles on it. It was recently refreshed in 2006 as a winter project with 98,000 miles on it. I challenge ANYONE to find a cleaner 2g or any brand of car this clean. I GUARANTEE there is nothing you need to do to this car. Please see the pictures AND videos in the link below. Please let me know if you have troubles accessing them as it's a free site. I don't know if there bandwidth restrictions. I strongly encourage you to view the videos. One is a walk around of the car, one is displaying how easily it starts up and the last video is showing how beautiful it shifts.
http://s236.photobucket.com/albums/ff127/onefast99gsx/
** click on any of the pictures to enlarge them **
Asking price is $9899.
PM me for ANY questions and I will respond promptly.
1999 Mitsubishi Eclipse GSX ABSOLUTELY NO RUST!!!!!!! Stored winters, covered.
** Engine recently freshened up in 2006**
New oil pump
New OEM Pistons & rings
New knock sensor
New OEM timing belt
New OEM balance shaft belt
ACL Aluglide crank & rod bearings
ARP Head studs
Head surfaced & block decked
PTE 50 trim turbo
SS braided oil line
Slowboy racing return line w/ AN fittings
Forced Performance 3” air intake pipe
Magnus 2g intake manifold
1g throttle body
PTE 780cc injectors
HKS 272 cams
SS intake & exhaust valves
Crower valve springs & TI retainers
Manley keepers
Bronze valve guides
New OEM lash adjusters
DSMLink v2.5 ** laptop will be included **
PLX wideband o2 sensor read by DSMlink
Jumptronix digital o2 voltmeter gauge
HKS Turbo Timer
Custom 2 ½” upper IC piping
Griffin Fount Mount Intercooler
4 ply silicone couplings with heavy duty t-bolt clamps throughout
19” Racing Hart C5 wheels ** Tires are near brand new **
TurboXS blow off valve
2 ½” downpipe
3” cat
3” RSR catback exhaust
Walbro 255lph fuel pump
Hallman manual boost controller
Taylor plug wires
Shaved Valve cover
Custom coil pack relocation mount
RRE catch can/ crankcase breather
(2) 1800cfm Mr. Gasket slimline fans
TRE built transmission - spring 2006 Redline MTL/MT-90 oil used
Fidanza aluminum flywheel
Southbend DXD clutch
Alky/water injection – controlled by DSMlink nitrous control feature
SS braided clutch line
New master & slave clutch cylinders
Prothane motor mount inserts
Autometer boost & EGT gauges
8000k HID Headlight conversion
Pioneer 6x9 back speakers
Pioneer 3-way door speakers
Pioneer 12” subwoofer
500x2 Amp Hollywood amp
Yokohama Parada Spec2 215/35/19 tires ** nearly new **
Tokico Illiumina adjustable coilovers w/ Eibach ground control springs
Also have a 2nd set of Eibach rear springs with more travel
Camber adjusted and professionally aligned
Professionally tinted windows - 35%
1yr old Duralast gold top battery
Air Conditioning blows good cold air
** Custom sliding front license plate bracket ** Slides up and down for use at car shows or at the track to keep from blocking the intercooler
Also included:
Factory 3 volume set service manuals
Original front exhaust *mint*
Original cams
Original 17” GSX wheels w/ brand new Wanli tires
Original 2g intake & throttle body
Original side mount intercooler
Original 450cc fuel injectors
Original ECU
Excellent condition. No part of this car has been under looked.
