Old 08-03-2011   #21
way2fastalon
IS Broken :-/
way2fastalon's Avatar
Re: tranny will not go in 1 3 5
manually put the tranny in first with out the cables hooked up hook the cable up and see where your shifter is ... if the cable wont hook up or let you out its the bracket for wrong year you might need to bend it the way you need it and check reverse too that is the longest shift for the cables you could have gotten 1g cables possibly witch are different?
1991 Eagle Talon awd
2.0 fully built lower-end
+more mods to list
