Old 08-04-2011   #6
19TsiAwd90
2stepadepaaadepaaadep
19TsiAwd90's Avatar
Drives: myself crazy
Re: FIC 750cc injectors
This is the response I got from fic when I emailed them
The possibility of using those injectors in your Subaru will depend on if the injectors in question are high impedance or low impedance. If they are low impedance you will need to have an aftermarket engine management to drive the injectors, or you will damage your computer. If they are high impedance, then you will be able to use them as long as the electrical plugs are included, as well as the seals.
So the question is are they high imp our low imp
And where can I get the required plugs
Originally Posted by 311evo
