Old 03-22-2012   #6
Perkul8r
Perkul8r's Avatar
Drives: 91 GVR4
Re: Looking for some info
Originally Posted by dsmghost View Post
In my opinion, before doing a leakdown test you should run a compression test. But if your shooting oil out of the dipstick you do have excessive crankcase pressure. Most likely rings or a damaged piston. But compression test for sure.
I wish I would have thought ahead of time about doing a compression test. I could still do one, the motor is pretty much just a longblock right now just sitting in the car.
I would have to find a tester though.
