Old 04-05-2012   #2
Re: Kenne Bell boost a pump wiring
How much more fuel are you gonna need? I'd say start with the standard wiring setup. Running dedicated power wires ends up complicating things and will make troubleshooting that much harder.
Be sure to install the 30a fuse in the stock fuel feed/fuse box.
Definitely ditch the dial box, all the reasons you listed are good enough, but in top of that they simply fail (the dial). I just bought an RCA plug from RadioShack and soldered the connectors together on the inside. I started with the dial box and tweaking it and honestly it didn't make enough of a difference for me unless it was set at full.
