Old 11-30-2012   #12
slammedndirty
slammedndirty's Avatar
Drives: 93 laser rs awd
Re: no start 1g
Other thoughts:
Massive vacuum leak
Verify all 4 plugs are sparking (maybe you have a bad coil, only running on 2 cylinders)
Base ignition timing (center the CAS in the slotted holes to start with)
BISS screw improperly adjusted
MAS bad or unplugged
Do you have a logger, or link, to look at some of these signals?
im buying a logger today hopefully and there is spark on all 4.. i will check the others
slammedndirty is offline   Reply With Quote
