Old 12-09-2012   #11
Re: GheyrodX - bigger, fatter, gheyer!
MAP EF2.5 installed and tuned by Cobb yesterday while I was in Austin, TX for an event.
426whp
393wtq
27.69 psig (peak) holding a flat 26 past redline.
Still on 93-octane pump gas and stock cams! Solid gains over the EF2, but definitely lost some spool and response. This is with the 3" anti-surge cover, but MAP also sent me a 3" standard cover so I'm thinking if I swap that one on I'll gain back some spool and response. I'll talk to MAP about it and go from there. The car is definitely a beast for a DD, and I believe this is the farthest Cobb has ever pushed the stock cams and it's getting up there for pump gas numbers too. My previous results on the EF2 were 413/384; peak boost was right about the same, ~27psi. I think this is yet another good turbocharger option from MAP. While not replacing any of the current models, it's a good fit between the EF2 and EF3 as intended.
small chart:
big chart:
