Old 02-04-2013   #2
Re: Stock Injectors
You can, but your fuel pump becomes less efficient and you can run in to issues with the injectors if you run too much pressure. You will need to run 20% higher pressure to get there assuming your pump can handle it, so ~46 base pressure if it is the 1g in your profile. If you keep the boost low you can probably get away with it if you have an upgraded pump.
