Old 03-07-2013   #11
Re: Project Lex
Well was hoping to have a lot more progress on this by now, but the wife and I came down with a pretty bad flu bug so haven't been to active.
Here's the little bit I've gotten done.
- Flywheel got the new friction surface on.
- Had two bolts welded into the adapter plate to act as studs for the starter. Drilled the start holes out. Worked out great. Thanks a million Kerry!
- Mounted adapter back onto motor.
- Mounted flexplate and FW adapter to motor (loctite)
Went to mount the FW, but I think I need some different hardware. The ARP ones don't work with my JWT Flywheel But all is good, Collins is sending me some socket head bolts that should do the trick
ID:	13374   Click image for larger version
ID:	13375   Click image for larger version
ID:	13377   Click image for larger version
