Old 03-19-2013   #11
Tachyon
Tachyon's Avatar
Drives: Icarus
Re: 2G auto S/A daily
This is what I ordered and hopefully will get a tracking # today.
Machined 16G j-pipe housing
Billet 11 blade 3076 comp wheel
td06h4 turbine wheel
Upgraded shaft
FP 8cm hotside
Holset wastegate
Crossing fingers it will do well. If the j pipe housing does become a huge restriction then ill just throw on a downfacing comp cover to help it out. Someone said Tachyon runs a downfacing in SA/U so ill just run that class instead.
My main goal for the car is to run a low 11 high 10. I think it's pretty doable to after seeing what the ef1 has done in carltalons full weight 2G last yr.
I'm super interested to see what the 11 blade 3076 comp wheel does in a correct housing. You should just join me in SA/U... that field could use some more cars
-Sebastian Vettel
