Old 04-01-2013   #11
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Re: joel's build
Turbotalon!?!?!?! Remember when you and Jim came up cause I thought it was blown up. Fixed the tune and could hear sloppiness in the trans and my throw out bearing was toast! Sounds like that.
I stopped over there for a minute and it sounds awesome running when pressure is applied to the pedal (alot of play in the pedal up top).
Our thoughts were in it got bled and adjusted it would hopefully make the noise stop. We will have to see. Worst case scenerio throw out bearing or flywheel bolts.
He used the arp flywheel bolts that Map sells. (Celica kit). I've heard that sometimes they don't go all the way in so maybe
Another note is he said it worked fine until he got to Acapulco in Blaine 15 mins or so of driving then the noise started. So to me it sound like a bleed and adjustment away from being good to go. Crossing fingers.
