Old 05-13-2013   #7
Re: Baby has new shoes!
Very nice, Steve! What offset did you go with? I have RP-F1's in 17x8.5 at 30 offset and I had to notch (grind) my front struts to get 2 degrees negative camber in the front.
45 in the front, 35 in the back, 17x9's all around. I was planning on doing a staggered setup with 17x10's in the back and 17x8's in the front, but I would've had to do MAJOR surgery to get the rears to fit.
I did have to notch the rear lower control arms like a few others have done, but that was simple.
I've got the eccentric front bolts for camber, but it's not enough, they are at about 0 right now. I need camber plates.
Not too surprisingly, against everything I've read, there are no clearance issues with regular Koni shocks and Eibach springs, coilovers are definitely not needed.
