Old 06-04-2013   #6
cmspaz
Walls need hugs too
cmspaz's Avatar
Re: How you're supposed to shift
Originally Posted by narshe View Post
I haven't looked into it, but is that safe? If the rev limiter is at 7,500 RPMs, and you don't lift your foot off the gas and shift close to 7,500, even if you weren't fast, would the engine have a chance of blowing? I know it can happen the RPMs are lower and get enough momentum, ala Bobby, but would that happen if you do it right at the cut off?
I haven't looked into it, but I'm sure there is an art to it.
If you're shifting a stock turbo Evo that high you will most certainly not be in the 10s. Gotta shift under the curve.
Originally Posted by Trogdor
