Old 07-03-2013   #20
carltalon
carltalon's Avatar
Drives: 98 Eclipse GSX Auto
Re: 99 ecu tuning?
If you are using the stock 99 CAS it is not ajustable. If you are using a 1g CAS ground the pin on the firewall and set the timing. What have you changed since your last tune? as long as you are using the same MAS and injectors your tune should be close enuf to drive around at low boost.
11.35 @ 120mph
