Old 08-19-2013   #21
Knoxville
Drives: 09 G8 GT
Re: Knoxville's Heads 'n Cam Swap Build Thread
Here are the old cam specs that I removed from the car if anyone was interested.
Comp 227/239 .613/.623 LSA 114+5
2009 G8 GT
Knoxville is offline   Reply With Quote
Old 08-19-2013   #22
93gtpeater
Drives: cbr 1000rr repsol
Is the cam good for boost?
Old 08-19-2013   #23
Knoxville
Drives: 09 G8 GT
The old cam is boost friendly if that's what your asking
2009 G8 GT
Old 08-19-2013   #24
93gtpeater
Yes. Pm info and price. I have a boasted 5.3
Old 08-19-2013   #25
Knoxville
Drives: 09 G8 GT
PM sent
2009 G8 GT
Old 08-19-2013   #26
Looking good man!
Dumb question, something looks wierd towards the bottom part of this piston. Just a goofy camera shadow effect thing or is there really a gap there?
Old 08-19-2013   #27
Knoxville
Drives: 09 G8 GT
I think what you are seeing in piston 1 is some oil pooling at the bottom of the cylinder. After I cleaned the pistons with some carb cleaner, I put some oil around each cylinder wall while it sits for a bit for the heads arrive.
2009 G8 GT
Old 08-20-2013   #28
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
Big motor power ftw.
Old 08-20-2013   #29
Knoxville
Drives: 09 G8 GT
I picked up a new Underdrive pulley to replace the OEM crank pulley that has the huge gouge in it.
Also I picked up a new crank seal to hopefully mitigate the risk of the new Underdrive pulley getting gouged as well.
In a holding pattern at this point for the pulley and heads to arrive so I can put this beast back together. Getting excited...
2009 G8 GT
Old 08-20-2013   #30
JohnnyT
JohnnyT's Avatar
Drives: C5 Z06
What UD did you go with? ARP, Powerbond, SLP?
Coming along well - time for a new intake mani too!
2002 QS Z06 | Futral custom grind cam | LG headers & GHL cat-back | FAST 92/90 | E85 | Corbeau A4s | CCW SP500s | Mantic ER2 clutch | GM T1 bars | 422whp / 405wtq (pre-FAST) | Tuned by Carl @ CJ Tunes |
JohnnyT is offline   Reply With Quote
Old 08-20-2013   #31
Knoxville
Drives: 09 G8 GT
I went with the SLP Underdrive.
I already have a Rick Crawford ported intake manifold. It actually was flow tested, dyno tested, and track tested against the FAST 102 and yielded better results.
He does something more than just porting the size of the manifolds, he builds some sort of structure on the inside that helps the air tumble more efficiently.
2009 G8 GT
Old 08-20-2013   #32
Murlo26
Murlo26's Avatar
LOL, I still don't buy that his intake mani is better, I think he blowing hot air at you.
I am sure its better than stock and for the price/performance factor it probably makes more sense. But hard to argue with every other LS platform out there that has awesome results with the FAST.
Old 08-20-2013   #33
The stock LS3 and LS7 intakes are actually quite good compared to the old LS2/6 manifolds, especially when ported they can keep up with a Fast 102. Not sure which one Knoxville started out with though.
Old 08-20-2013   #34
Murlo26
Murlo26's Avatar
Well maybe I stand corrected
I just have a hard time believing the guy selling the stuff, of course he will talk it up, he needs to make money.
Old 08-20-2013   #35
Knoxville
Drives: 09 G8 GT
Take a look at Crawfords facebook page and search for "Let the games begin! Ported FAST 102 .vs Rick Crawford AirRam L76." Read the comments for flow test results:
https://www.facebook.com/RickCrawfor...ation=timeline
For more information about Rick Crawfords ported Intake Manifold and many success stories:
http://g8nation.com/showthread.php?t=30615
Many people in the G8 community have seen gains with Rick Crawfords Airram Manifold. He is not just blowing "Hot air" at us. As you can see here he picked up gains on the dyno of an already typically ported intake manifold, and this test was done independently of Rick (search for "Rick Crawford Intake manifold ported results"):
https://www.facebook.com/pages/New-E...e/392922230272
The FAST 102 costs over twice as much, weighs much more than the stock manifold, and hasn't yield gains that are worth it to me.
2009 G8 GT
Old 08-21-2013   #36
Huh. Sounds like every parts maker out there to me.
Old 08-28-2013   #37
Knoxville
Drives: 09 G8 GT
I'm getting excited for the new beef
2009 G8 GT
Old 09-04-2013   #38
JohnnyT
JohnnyT's Avatar
Drives: C5 Z06
The LS6 is actually pretty damn good. Most claim you'll outflow the 243 heads before the mani. The LS1 and 2 are complete junk though.
Get everything wrapped up yet, Knox?
Old 09-04-2013   #39
Murlo26
Murlo26's Avatar
He is out of town right now, i think this weekend he is targeting to finish it up.
Old 09-07-2013   #40
Knoxville
Drives: 09 G8 GT
Just got home from a business trip yesterday. Picked up my new Rick Crawford heads and started working on the car. Made some progress, and this beast is getting closer to completion. Really looking forward to this first startup.
New Rick Crawford Heads:
Installed heads, pushrods, rocker arms, headers, under drive pulley, power steering pump:
2009 G8 GT
