Old 11-02-2013   #1
punxnotdead185
Drives: 95 AWD Mirage Coupe with AIDS
Parting out my TSi, lots of good performance parts
Alright I've decided to let go of this thing because I've come to the conclusion I am never going to finish it, here is a list of what will be for sale. If you want pics you'll have to ask. I'm sure I have more this is just what I could think of off the top of my head. PM me or text 6512786390.
-Car, 1991 Talon TSi AWD, almost completely rust free, its silver with black fenders, has 17" 2GB GSX rims on it and good KYB GR2 struts, the title has the buyer info already filled out when I got it, was going to be a track car so I didn't really care at the time. Been told it could be fixed with a title correction form. $400
-Engine parts,
I have a set of .020 over JE pistons, the have the 22mm wrist pin and have some scuffing on the skirts, not too bad though and they were pulled from a running motor. $100
I also have 2 1g heads, both need valves, they have all the cam caps though so good cores for rebuilt heads. $40 each
I also have both a 2.0l 7 bolt crank in good shape. Was saving for 2.1 long rod motor. $50
-Turbo parts,
I also have an EF3 with a Typhoon down firing comp cover and a cracked ported 14B turbine housing bored out for the TD06H turbine wheel, flapper is welded shut because I have a manifold with a 44mm wastegate on it. Rebuilt and balanced. $400
-Manifolds,
I have a 2g exhaust manifold with a 44mm Tial MVR flange welded on and will come with a good eBay 44mm wastegate, the collector area is ported also, don't know if this will fit on a car with power steering. $100
-Intercoolers and piping, half size intercooler 12" tall 3" thick one for when I was going to do a forward facing compound setup, painted black. $40
-Fuel system parts,
One is just an ebay regulator, worked fine for me with a walbro 255 on e85, its a 2g -6an fuel rail adapter with a 90
deg -6 elbow that goes straight to the regulator with a barb fitting on the bottom for the return line, can include the 2g rail also. $30
10ft of -6an steel braided line. $30
punxnotdead185 is offline   Reply With Quote
