Old 12-16-2013   #1
ryukinevo
Drives: 2003 evo 8
Post Iowa:Post-build oem/aftermarket evo 8 - 9 converted:Garrett,AEM,ETS,AMS,FIC,STM,EXEDY
POST UPDATE: BUYERS NEEDED!!!
THIS IS AN ONGOING THREAD EVEN THOUGH DATED IN DECEMBER. I UPDATE THIS THREAD ON A CONSTANT BASIS AS PARTS SELL!
PLEASE DO NOT LOOK AT THE DATE AND ASSUME THAT IT IS SOLD!
IF IT'S SOLD, IT IS IN THE RED SECTION MARKED SOLD TOWARDS THE BOTTOM OF THE THREAD!
I ORIGINALLY HAD OVER 100 PARTS LISTED, MUCH HAS SOLD, BUT STILL A LOT OF PARTS LEFT. PLEASE PM ME ABOUT THE PARTS STILL FOR SALE, THANKS!
Hi evo/dsm owners! My evo 8 changed from adding a turbo kit, to a clutch rebuild, to a full built evolution 8 to 9 conversion project! I paid a lot of money through the course of this project; my loss is your gain! Unfortunately winter has hit the midwest and I am still working on it!
  • Due to my procrastination, I have posted everything that is currently out of the car and most parts are ready to ship after my paypal has cleared,
    pm for paypal address after agreement to purchase part.
  • PRICES DO NOT INCLUDE PAYPAL FEES OR SHIPPING, and I will only charge actual shipping cost with insurance via usps, UPS, Fedex.
    Please be serious upon purchase before asking for shipping quotes!
  • If a price is out of line with the market cost, do not be afraid to make an offer; however I have done the research and believe these are accurate evolutionm going rate prices. The worst thing is that I would say no!
    Please contact Scott via pm or cell #:
    http://www.hidetext.net/hide/mMaqGfFqy9.gif
    Please see my evolutionm, evomn thread, and local craigslist for evo or Honda parts links:
    http://forums.evolutionm.net/sale-pa...stm-exedy.html
    http://www.evomn.net/forums/showthre...-FIC-STM-EXEDY
    http://desmoines.craigslist.org/pts/4453428809.html
    http://desmoines.craigslist.org/pts/4453443473.html
    Flickr for all pictures not displayed in post:
    http://flic.kr/s/aHsjQq6Qi7
    Aftermarket evo parts: 3k or less miles unless noted otherwise:
  • Power Stop front/rear slotted rotors (cryotreated) - $350
  • Hawk front pads (1 pad has scrap in it, not sure if this is issue or not) - $75
  • Hawk rear pads - $75
  • AMS motor mounts (side/transmission) (red) - $200
  • GREDDY Profec b spec 2 boost controller (1 connector pulled out when removing from car) - $200
  • Buschur Racing Rear Side Diff Supports (solid/race) BNIB - $330
  • Yonaka Racing radiator BNIB (Yonaka discontinued: Great deal on new radiator including shroud w/ dual slim fans unlike Mishimoto that you have to buy separately!) - $300
  • Fidanza cam gear (black) - $100
  • STM block-off plate w/ emblem BNIB - $15
  • FIC fuel injector seals (Used 1,500K from 2150s) - $20
  • dimple oil drain plug (1 oil change) - $30
  • Precision Turbo PTE6262 5 bolt turbine housing Tirado Custom Coatings gold ceramic coated BNIB (TCC does perfect work, but 3 month wait) - $150
  • EXEDY Twin HD (Needs rebuild, 35K) - $600
  • Vibrant MAF adapter BNIB - $20
  • Perrin cone filter (red) BNIB - $40
  • evo NGK (R5671A-7) spark plugs set BNIB (Autolite box) - $10
  • RALLIART shoulder pads (red) - $10
  • MOMO shoulder pads (yellow) NEW no box -$15
  • APR GTC-200 carbon fiber side plate ( AA-100048 ) - $45
    evo 10:
  • evo 10 Beatrush front license plate bracket BNIB - $50
    Universal evo parts:
  • ALTEC PRODUCTS Show-N-Go motorized front license plate w/ remote BNIB - $100
  • Ichibahn valve stem caps (yellow) - $8
  • Pilot led side marker lights BNIB - $20
  • Lightning Audio 1 farad capacitor BNIB - $50
  • 1/2" 20 x 3/4 oil drain plug BNIB - $10
  • -8AN braided stainless line (w/new straight fitting (black) not yet installed) - $30
  • Silicone reducer coupler (black) - $5
  • Spider lite led bulbs (red) 7443 BNIB - $20
    oem evo 8/9 parts: 42K or 52K miles unless noted otherwise:
  • evo 8/9 crank (42k) - $350
  • evo 8/9 intake manifold ($100) and throttle body (42k no sensors) - ($75) - Currently assembled, but can be separated
  • 4 evo 8/9 oil cap - $10
  • evo 9 cams (42k) - $75
  • evo 8 upper timing belt cover - $35
  • evo 8/9 oil pump (42k) - $75
  • evo 8/9 trunk (red) (Paint great condition w/ small amount rust by wing mount holes) - $250
  • evo 8 carbon fiber oem wing (Red, near perfect clear coat) - $275
  • evo 8 front bumper duct - $20
  • evo 8 front bumper oil cooler duct - $25
  • evo 8 rear bumper bracket 1 - $10
  • evo 8 rear bumper bracket 2 - $10
  • evo 8/9 hood release latch - $15
  • evo 8/9 radiator brackets (No rubber) - $5
  • evo 8 engine harness (52k) (SOLD AS IS: Was perfect harness, but had to cut some wires due to evolutionm vendor sold undisclosed damaged evo 9 harness ): - $200
  • evo 8 chassis/headlight harness - $130
  • evo 8 dash harness (Some wires patched into for alarm) - $130
  • evo 8 transmission wire harness (52k) - $50
  • 2 evo 9 chassis/headlight harness (SOLD AS IS: evolutionm vendor sold undisclosed damage/modified harness) - $100 each
  • evo 9 dash harness (SOLD AS IS: same above evolutionm vendor) - $100
  • evo 8/9 horn (SOLD AS IS: same above evolutionm vendor) - $15
  • 2 evo 8/9 flywheels (35k/42k) - $75 each
  • evo 8/9 turbo exhaust manifold (42k) - $80
  • evo 8/9 turbo exhaust manifold heat shield w/ bolts - $10
  • evo 8/9 O2 housing (42k) - $60
  • evo 8 spark plug cover - $25
  • evo 8 front license plate bracket - $25
  • evo 8/9 balance shaft (52k) - $20
  • evo 8/9 cd player (25k) - $25
  • evo 8/9 front brake lines (52k) - $20
  • evo 8/9 rear brake lines (52k) - $20
  • evo 8/9 fuel pressure solenoid (52k) - $30
  • evo 8/9 undertray (center panel only) - $25
  • evo 8/9 extended fuel feed line - $10
  • evo 8/9 EGR system (52k) - $50
  • evo 8/9 EGR valve (42k) - $25
  • evo 9 oil pressure switch (42K) - $10
  • evo 8 clutch fork and springs (52k) - $30
  • evo 8 firewall relay (52k) - $15
  • evo 8 alternator brackets - $25
  • evo 8/9 turbo lines - $25
  • evo 8/9 vacuum bracket (valve cover) - $5
  • evo 8/9 vacuum bracket - $5
  • 2 evo 8/9 intake manifold bracket - $5
SOLD
  • Avid Racing front mount BNIB - $50
  • evo 8/9 lower timing belt cover - $35
  • STM full master to slave clutch line BNIB - $40
  • Buschur Racing catch can BNIB - $230
  • evo 8 valve cover - $150
  • Buschur Racing double pumper (AN) - $425 shipped
  • Magnus Motorsports fuel rail (black) - $100
  • AEM evo 8 series 1 uego (1313U) sensors/cables - $650 shipped
  • evo 9 springs/retainers (no keepers) - $60
  • evo 8 front bumper nose screen - $50
  • ETS mini battery kit w/Odyssey PC-680 battery - $200
  • FIC 1450 injectors - $375 shipped
  • evo 8 gauge cluster (52K) - $100
  • Buschur Racing double pumper - $425 shipped
  • evo 8 alternator/starter charge wire harness - $35
  • evo 8 rubber petal covers - $10
  • evo 8/9 COP & plug wires (42k) - $75
  • 4" MAFless intake pipe w K&N filter (black) - $100
  • evo 8 ecu (52k) - $200
  • Buschur Racing/Supertech dual titanium springs/retainers BNIB - $300 shipped
  • 3" intake pipe w/ K&N filter - $40
  • AMS LICP - $200
  • MOMO hood pins (gold) BNIB - $30
  • evo 8 coolant tube - $30
  • evo 8 thermostat housing - $50
  • evo 8/9 cam sensor housing - $15
  • evo 8/9 pistons/rods (42k) - $100
  • Heat barrier intake manifold gasket - $20
  • AMS (short route) UICP w Tial bov = $450
  • evo 8/9 front crash beam - $60
  • evo 8/9 front crossmember - $40
  • evo 8/9 front engine mount - $25
  • evo 8/9 drive shaft carrier bearing support bushings (52K) - $15
  • FATHOUSE Fabrications GT3582R turbo kit - $2,600 shipped
  • Autometer sport comp 30psi boost gauge - $50
  • STM style oil cooler kit with -8 lines - $100 (Blew head gasket @1,500 miles so oil cooler sold as is) - $100
  • AEM evo 9 series 1 (1320) w/ MAP 3.5 bar (30-2130-50) sensor adapter/cable - $625 shipped
  • evo 8 complete head with cams (52k) - $575 shipped
  • evo 9 head timing cover mounting brackets - $40
  • Greddy radiator cooling plate/diffuser (silver) - $100
  • evo 8/9 intercooler pipes - $60
  • ETS (short route) UICP (Missing lower pipe because using for Magnus intake manifold) - $100
  • Honda S2000 antenna BNIB - $25
  • evo 8/9 intercooler reservoir w/ tubing & 1 sprayer - $25
  • evo 9 ACD transfer case rubber line - $35
  • evo 8 front bumper nose (Styrofoam) - $10
  • PWR 92-00 Honda Civic half radiator (polished tank) BNIB - $200
  • MISHIMOTO radiator 12" slim fan (red) BNIB - $70
ryukinevo is offline   Reply With Quote
Old 12-18-2013   #2
ryukinevo
Drives: 2003 evo 8
Re: Iowa:Post-build oem/aftermarket evo 8 - 9 converted:Garrett,AEM,ETS,AMS,FIC,STM,E
Bump!
I know some of my parts work for your dsm.
I have interest in my cam gear and evo 8/9 springs & retainers sold yesterday!
Old 12-18-2013   #3
ryukinevo
Drives: 2003 evo 8
ETS mini battery kit w/Odyssey PC-680 battery and
FIC 1450 injectors sold!
Any questions, pm me!
Old 12-28-2013   #4
ryukinevo
Drives: 2003 evo 8
evo 8/9 COP and plug wires (42k) Sold!
Are there any evo guys on this forum or is dsm guys that need evo parts?
Old 12-30-2013   #5
ryukinevo
Drives: 2003 evo 8
evo 8/9 4" MAFless intake pipe with K&N filter (black) - $100 Sold!
Post updated with the following added parts:
  • 2 evo 9 chassis/headlight harness - $100 each
  • evo 9 dash harness - $100
  • evo 8/9 horn - $15
  • evo 8 intercooler sprayer switch (52K) - $15
Thanks!
Old 01-04-2014   #6
ryukinevo
Drives: 2003 evo 8
Bump ):
Old 01-06-2014   #7
ryukinevo
Drives: 2003 evo 8
Post Re: Iowa:Post-build oem/aftermarket evo 8 - 9 converted:Garrett,AEM,ETS,AMS,FIC,STM,E
These parts have sold, but more for sale and some part prices lowered!
  • evo 8 ecu (52k)
Old 01-11-2014   #8
ryukinevo
Drives: 2003 evo 8
Thumbs up Re: Iowa:Post-build oem/aftermarket evo 8 - 9 converted:Garrett,AEM,ETS,AMS,FIC,STM,E
These 2 parts sold!
  • 3" homemade intake pipe with K&N filter
  • AMS LICP
Thank you to those that have purchased so far, but need more buyers over 100 parts for sale!
Still working on the picture links, please use photobucket link at bottom of my post until I switch to flickr?
Old 01-13-2014   #9
ryukinevo
Drives: 2003 evo 8
This took forever to figure out ): Picture links fixed I hope!!!
MOMO hood pins sold!
pms returned, who else has a question!
Old 01-20-2014   #10
ryukinevo
Drives: 2003 evo 8
Bump, mitsustyle need more buyers!
New part listed: FIC fuel injector seal set (used 1,500K from 2150s) - $20
Following parts have sold:
  • evo 8 coolant tube (52k)
  • evo 8 thermostat housing (52k)
Thank you to those that have purchases!
Last edited by ryukinevo; 01-21-2014 at 01:02 AM.. Reason: Forgot new listed part!
Old 01-29-2014   #11
ryukinevo
Drives: 2003 evo 8
Bump!
Old 02-16-2014   #12
ryukinevo
Drives: 2003 evo 8
Weekend bump!
Old 02-18-2014   #13
ryukinevo
Drives: 2003 evo 8
Exclamation Re: Iowa:Post-build oem/aftermarket evo 8 - 9 converted:Garrett,AEM,ETS,AMS,FIC,STM,E
Bump!
Old 02-20-2014   #14
Fejery4491
Fejery4491's Avatar
Drives: 97 Mitsubishi Eclipse GSX
Free bump. Just received my parts today and I'm very satisfied. Price was right, shipping was quick, and parts were very carefully packaged. Very good seller!
Fejery4491 is offline   Reply With Quote
Old 02-20-2014   #15
ryukinevo
Drives: 2003 evo 8
Thanks fejery4491. I am glad you are happy with your part!
Old 02-25-2014   #16
ryukinevo
Drives: 2003 evo 8
Bump, any dsm/evo guys out there besides fejery4491 ?
Wow this is kind of out of date, a lot has sold since oil cooler.
I will update this soon!
The following parts have sold:
  • evo 8/9 EGR system (42K) - $50
Thanks!
Old 03-01-2014   #17
ryukinevo
Drives: 2003 evo 8
Saturday night bump!
Old 03-13-2014   #18
ryukinevo
Drives: 2003 evo 8
Bump, still alot of good evo 8-10/dsm parts for sale!
Old 03-28-2014   #19
ryukinevo
Drives: 2003 evo 8
Not bumped for awhile, evo 9 intercooler pipes sold!
Old 04-08-2014   #20
ryukinevo
Drives: 2003 evo 8
Bump!
