Old 08-13-2014   #2
Re: Fuel Pressure Issue
Where was the fuel leak? At the sending unit to tank seal?
Possibilities for pressure not rising above 38 at idle could be a leak in the feed line inside the tank bleeding off all the fuel above 38psi, or a bad regulator. I had a bad line bleeding off pressure inside the tank before, but on a different car. Even a bad pump should he able to make more than 38psi at idle.
