Old 03-27-2015   #4
blesi660r
blesi660r's Avatar
Re: WTB: extended slave rod
The clutch pedal assembly will be fixed also I noticed today that I might have to pull the Trans and shim the pivot ball, so more or less the extended slave rod is being used for tests ONLY and not as a permanent fix trust me lol I have to much time into this car now to half ass! When I pull my Trans next it will be to replace the used clutch and flywheel I put in to get the car running not to just shim, till then I'm going to use the bandaid fix along with fixing my pedal assembly, that will be being pulled later this weekend.
Just couldn't stay away.
