Old 07-28-2004   #12
FORSFED
No, take everything out of the way you possibly can. Take off the wheels. Also there are two subframe pieces that should come off real easy. One is a long crossmember that runs underneath the tranny (I'm guessing this is out already if you got the tranny out) and the other one is next to that and looks sort of like a triangular piece held in with 5 bolts. Then all you need to do is follow my instructions above. You will need to angle the tranny a bit to make it clear everything on the cars way down, so go SLOW. Other than that, good luck.
FORSFED is offline   Reply With Quote
