Old 11-01-2016   #7
Re: 97 GSX -The Rebuild
Originally Posted by mark4g63t View Post
Got the engine back together.. should be going back in this week.
Put a straight edge on your cam gears and line up the marks with the center of the bolts, your marks look off a bit. The belt tension looks a bit tight as well, but that might loosen up once you rotate it several times.
