Old 12-29-2017   #11
Mark Leasure
Mark Leasure's Avatar
Re: Mark's 1G Winter Projects
The cage is done! I'll be getting it certified next month. It's been an awesome project. The seat mount and belts are done too.
I also removed a little more than 10 more pounds of metal from the front driveshaft carrier bearing mount and supporting structure from driveshaft tunnel. This sucked to remove, i was drilling spotwelds for 3 to 4 hours! It was well worth that time for that much of a weight reduction. I'll need to get this thing on corner scales to see what it comes out at.
To remove the driveshaft support structure I had to cut out emergency brake cable bulkhead from the floor. I got to use my bead roller and made a patch panel, and plug weld at all the areas where I accidentally drilled through while removing the spot welds. I also stitch welded back in the floor section I cut for the tube that intersects it.
www.maperformance.com
