Old 03-07-2018   #941
Mark Leasure
Mark Leasure's Avatar
Re: Mark's 1G Winter Projects
Originally Posted by Dark2g View Post
Nice work on the certification, and I think carbon doors are gonna cut alot of weight. Are doors carbonetics as well?
Yep carbon/kevlar doors too.
The doors save alot of weight! Way more than I expected. My old doors have the cross beam removed and as much of the sheet metal on the front removed. The new doors have polycarbonate windows that dont roll down, this helps on weight too. The total weight saved per door is a bit over 34 pounds!
www.maperformance.com
Old 03-10-2018   #942
Mark Leasure
Wiseco is sponsoring my new MAPerformance engine build by supplying buck wild custom hp pistons/rings/wigged out TP1 coated pins!
Also, I just finished painting the interior and cage. Super pumped how it turned out! I used paint code mixed cans and 2 part 2k clear coat in a can. Very easy to get great results! I also used carbon tube protectors to protect the paint.
Looking forward to a great season!
Old 03-10-2018   #943
Looks amazing. You going to run their new rods too? Or maybe you run aluminum ones, I forget.
Old 03-11-2018   #944
MorningWood
Drives: Evo 8, 2014 Silverado
That turned out really good!
MorningWood is offline   Reply With Quote
Old 03-11-2018   #945
Wow that looks great!
Old 03-19-2018   #946
Mark Leasure
Little teaser of the project. It's coming along nicely! The interior is complete now! I need to repaint the side mirror deletes, work on some side trim, and determine if I'm going to cut out an intercooler opening. It's going to be an awesome day when I get it all wrapped up! This was the largest winter project I've taken on.
Old 03-19-2018   #947
Speedfreak
Drives: four tires
Looks amazing. You are a machine.
NSX - S480/Built motor
GSX - 571whp/490wtq
Sienna
Old 03-19-2018   #948
Dark2g
Drives: 2gb gsx
Looks like all the carbon stuff fits well! You have outdone yourself as usual, have you already weighed it?
Old 03-19-2018   #949
Agree with mo. Amazing.
Old 03-19-2018   #950
Wowza
Old 03-19-2018   #951
MorningWood
That looks mean! Can't wait to see it go down the track!
Old 03-20-2018   #952
Looks amazing!
Old 03-20-2018   #953
93gtpeater
Drives: cbr 1000rr repsol
Looks very nice. I do love the carbon front half of the car. Hope to see this flying at the track this year
Old 03-20-2018   #954
SlowWhite
Been there, done that.
SlowWhite's Avatar
Absolutely unreal that car is gorgeous
1997 GSX - new ride
2004 R6 - sold
1992 GSX - sold
1996 GST - sold
1995 GSX - sold
Best 1/4 - 11.7 on 93oct
Best 1/4 MPH - 120mph
Old 04-25-2018   #955
Mark Leasure
First off, thanks guys! This is going to be a building year for me, with so many changes.
The new chassis work is almost done. I had a problem with trim with the carbonetics fenders, the factory trim would not work. (Even with significant mods)
I learned that I needed to use Eclipse rear trim to eliminate the the eagle talon side/rocker trim. So fast forward, I removed the trim and it uncovered a rust spot on the passenger side and a big dent on the drivers side. I patched in new steel on the passenger side. This sucked, and was a good for me to learn body work...i also patched the holes for the trim mounting locations.
What is crazy is this was all done with custom paint mixed and 2k clear cost aerosol cans!
I also cutout the intercooler opening, I was unwilling to keep the front end closed off after research on the benefit. I built air guides on the intercooler to match the bumper profile.
Super pumped to get this project wrapped up and get it down the track!
Old 04-25-2018   #956
Fran05
Drives: DSM
^this last image is wallpaper material
Old 04-27-2018   #957
love it so much. That FMIC is huge!
Old 04-30-2018   #958
SlowWhite
SlowWhite's Avatar
Just noticed your hood pins. I was thinking about doing those for various pieces on my car.
What are your thought so far about them. Granted your using them to hold your hood, so that definetly says something by itself at the speeds you run.
1997 GSX - new ride
2004 R6 - sold
1992 GSX - sold
1996 GST - sold
1995 GSX - sold
Old 05-03-2018   #959
You and Troy are killing it this season Mark, looking forward to seeing you guys at the track this year!
Old 05-03-2018   #960
DSMINMN
Mitsus for days!
DSMINMN's Avatar
Drives: '08 Chrysler 300C
Siiiiick stuff!
Copyright ©2000 - 2024, Jelsoft Enterprises Ltd.
