Old 08-17-2004   #5
tsiawdspeed
tsiawdspeed's Avatar
Send a message via AIM to tsiawdspeed
I dont think that way will work but I also don't really know how the stock BCS works. Here is my theory and please correct me if I am wrong. Under low boost, the BCS is open so the wastegate is not seeing any boost, and therefore stays closed. When you hit enough boost, the BCS closes and the wastegate sees that boost and the wastegate opens up. So, I think, the way you have it set up, the wastegate will be seeing boost until it hits the stock boost setting and then it will boost more because the BCS will close, which cuts off the boost from the wastegate so it can't open.
tsiawdspeed is offline   Reply With Quote
