Old 10-29-2004   #13
LightningGSX
Hellbound
Since he asked what he needs to install it and not how it compares to others....
The cyclone is designed to give better LOW end, while keeping a decent top end.It has a valve that switches between either high velocity runners or high flow runners.For it to work properly you need some electronics to actuate the valve at the correct RPM.I'd recommend just buying a RPM adjustable nitrous switch, and using that to actuate the solenoid.
-Nulli Secundus-
