Old 12-04-2004   #7
JasonR
Guest
Tournaments Won: 6
Posts: n/a
Originally Posted by JasonR
Where is it leaking exactly Josh. Take a flash light and look under tranny if you can. You can drain the tranny fluid and inspect. Then make sure correct amount when adding new tranny fluid. Use large wrench for leverage. Hope for the best. Hey is the car running well besides the tranny. Jason.
Maybe the clutch release (slave) cylinder is loose or the line is loose. The connection of clutch tube. High pressure hydrolic line. Needs to be tourqued 12 ft ibs. Hydraulics failing. If the release cylinder push rod does'nt work the release fork wont. I think it is 12 or 14mm to tighten the clutch tube connected to slave cylinder. Do this and just add as much fluid as you can until it over flows. The system hydraulic probably needs to be bleeded again. I dont know I could be wrong. Hope not. If you have chiltons it is under 7-18, figure #43. Good picture of tube connected to slave cylinder.
