Old 12-10-2004   #18
caustad
Ok so I checked to see if there was power at the fuel pump check terminal while cranking over the motor and there was not. Also, the CEL was not on while turning over the motor. I put my hand on the MPI relay and it clicks when I turn the key on too. Is there any reason to check the CAS at this point? or should I just look for a wiring problem after the relay?
caustad is offline   Reply With Quote
