Old 12-16-2004   #4
carltalon
carltalon's Avatar
Drives: 98 Eclipse GSX Auto
Re: logger cable question.
This is how mine works
1) Locate the 3 plugs (Disregard the plug colors). Notice how one wire has only 1 plug and the other wire has 2 plugs.
2) Locate the diagnostic port in the lower driver side panel. It is right by the fusebox.
1 | Pin 1 is the very top left pin
| | Pin 10 Is on the lower right side along with pin 12
| | Remember to skip Pin 11!!!!!!!
| 10 |
| 12 |
Locate the single wire with 2 connectors, The plugs go into Pin 10 and 12 , It does not matter which of the 2 plugs go into which pin.
Locate the Single wire with 1 connector; this plug goes into pin 1.
Make sure the connectors are in tightly.
