Old 11-28-2003   #16
TheBlizzard
TheBlizzard's Avatar
Drives: Too Many
If use 245's you will most likely have to grind the upper control arm a little. Jet and I had to grind mine a little when I put my 18" Konig Caffeines on. They are 235/40/18 with Dunlop W10 Tires on them. And they are still really close to rubbing. You can always order the spacers for them though if they are too wide to grind. Or you can ghetto fab it and use washers around the lug bolts.
That is what you will most likely have to do though. 245's will rub like hell.
Jets 1G didn't have to be ground down for his 235's to fit but it doesn't have the the upper control arm on it either so it fit ok.
Fucking 2Gs and there wannabe cadillac suspensions parts.... :3gears:
