Old 01-15-2005   #34
Re: Track Time, maybe.
Originally Posted by CRAIG
Yeah thats a good idea. Just curious how much timing your are seeing running 24lbs on pump gas? And if you are seeing any knock?
CRAIG
It was a really clean run for timing, except for 4th gear.
1st gear, no knock
2nd gear, 1.1 deg knock in 2 spots
3rd gear, .4 deg knock in 1 spot
4th gear, 3.5 deg knock retard towards the end, probably due to heat build-up in the cylinders.
That was on 18.1 total timing @ 7000+ rpm. 820 deg C EGT.
I plan to take the timing down a little more to be on the safe side. Other than 4th gear, the engine seemed to do good.
If anybody is running DSMLink v2.5, I can send a copy of the run.
