Old 04-21-2005   #3
Re: 2g with 50trim intercooler plumbing help needed
Where is the other intercooler inlet/outlet at? The inlet should be on the drivers side and the outlet on the pass side. 90* out of the turbo, over to the side, then 180* into the IC. Compound bend coming out the other side, then up to the TB. You aren't thinking of using all rubber hose are you? If so, there is this cool black eclipse on carsoup.com that you should check out!
