Old 05-15-2005   #1
Wizard
Re: Rear Diff.
You can't do that unless you have a welded center diff, welded VC or VC eliminator. Without one of thos items, the car will drive like it has a slipping clutch. And after a while you'll burn up your VC.
A welded or VC eliminator is fairly cheap and easy to install. No need to remove the tranny even. This can also be used for dyno's.
Wiz
